Anyone Using a BBK Intake? Inj O-ring Question
Appreciate any feedback.
Are you going with the LS3 injectors because they are 42 lb compared to the stock LS6 28.8 lb injectors?
I would try LS6 o-rings or NAPA has a good selection of generic o-rings.
This will be a pump gas turbo setup. The injectors are the Holley 100lb that have the LS3 height. I have what would normally be the correct o-rings for intake, but after doing some research, I've discovered that the bottom o-ring groove on the injectors have a larger o.d. than regular LS1-style injectors. So, when the o-rings are installed, the o.d. of the injectors expand. I've discovered o-rings that have the same o.d. but the listed specs shows they have a larger i.d. They are Holley part # 534-104 and hopefully will solve this issue.
I don't know if the bottom o-ring groove of OEM LS3 injectors is the same as the Holley injector, but hopefully this info will help some someone else.
