Leaking injector?
Old Nov 5, 2025 | 02:03 PM
occhevelle's Avatar
Default Leaking injector?
I was doing a fuel pressure test on my 5.7 LS1 and got a reading of 63 lbs while running. When I shut it off, it did not immediately lose pressure, but it slowly dropped. After about 10 minutes it was down 8 lbs. I wasn't finding anything exactly addressing this in my search, but would a slow leak like this point to a leaky injector? Or something else? Or is a slow leak somewhat normal? Thanks in advance.
Old Nov 5, 2025 | 02:55 PM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I don't necessarily see any problem with those results. Losing 8psi after 10 minutes of shutdown isn't alarming to me at all, and 63psi under all running conditions is excellent (should be 58-60psi at all times with engine running, but the gauge might be reading a little high).
What initial concern prompted you to start a diagnostic process?
Old Nov 5, 2025 | 03:10 PM
occhevelle's Avatar
Thanks for the response. I’ve been chasing several little problems, one of which being the car running rich. I’ve charged a bunch of senses and tried several things but no luck so far
Old Nov 5, 2025 | 03:21 PM
RPM WS6's Avatar
Well, 63psi is technically a little high. If your gauge is extremely precise/high end, and that's a correct reading, it really shouldn't be more than 60psi (58-60psi is normal and proper for an LS1 application) so that might be contributing slightly to a rich condition. But that shouldn't really matter unless you're on a base tune for a given injector size. If it's been dyno tuned then it shouldn't matter unless something changed with pressure after the tuning.
Old Nov 5, 2025 | 04:05 PM
occhevelle's Avatar
Ok. I’ve got a 222/226 cam, ported heads, Walbro 255 fuel pump, upgraded injectors, and it is tuned. Would any of this account for the pressure being too high? And my gauge is not high end at all - rental from AutoZone
Old Nov 5, 2025 | 04:31 PM
Full Power's Avatar
Rental gauge is lucky if it has %5 accuracy, so don't worry about the number: You know you have fuel pressure, call it good.
WALBRO255 are fairly well known for bleeding down pressure through check valve in tank... as long as it PRIMES and starts relieably: You do not have a problem there.
Old Nov 5, 2025 | 04:33 PM
occhevelle's Avatar
Thank you so much for the info I really appreciate it. Last question - I’m guessing this slow leak etc would not cause it to run rich correct?
Old Nov 9, 2025 | 11:52 AM
G8 Drew's Avatar
Question is the source of the slow leak down. If it’s the pump check valve slowly leaks. Not a problem because your pressure always come back for start up. If it’s an injector. Start to see if one or more spark plugs are darker from being over rich. Safe way is to remove the injectors and have them tested. In the machine they can apply fuel pressure and not fire them to see if they leak. The backyard way is to pull the fuel rails with pressure still in them to see if they drip.
Have to catch any leaks so you don’t have a fire.
 Michael S. Palmer
