Fuel Pump??? NEED HELP ASAP!
Old Jul 30, 2004 | 09:20 PM
LittleBef15's Avatar
Default Fuel Pump??? NEED HELP ASAP!
Car cranks but doesn't turn over. I just filled gas with the usual 91 octane just before the incident. Battery gauge looks normal when I turned to on position and is well above 13 volts so I don't think this is the problem. Is this a fuel pump problem?
Old Jul 31, 2004 | 12:17 AM
Well after talking to a mechanic on the phone we are assuming it is the fuel pump...no gas is squirting out like it should and we can't hear it run when turning the key to on. Right now, it is sitting on a trailer inside my gf's dad's warehouse. Looks pretty good sitting on a trailer Luckily there is a mechanic next door so hopefully tomorrow I can find out what's going on with it and how much damage it will be. It started out to be a great day but now it is the
Old Jul 31, 2004 | 08:21 PM
rwb's Avatar
rwb
Do the obvious, check the fuse in the engine compartment.
Old Jul 31, 2004 | 09:47 PM
Did that already. So far it is costing 288 without shipping. That is from Gm parts direct online. arg
Old Aug 1, 2004 | 12:39 AM
x phantom x's Avatar
STF veteran / 10 second club
I'd get an aftermarket higher flowing fuel pump while your in there anyways .... unless you don't plan on modding your car ever.
