Stock Injector Flow Rate question...
Old Aug 9, 2004 | 09:02 PM
slyws6's Avatar
Default Stock Injector Flow Rate question...
Just out of curiousity, the 99 Injectors are rated to be 26lb injectors. Now considering they came factory on our cars, was that 26lb's rated at the 58psi line pressure that we run or is it at the standard 43.5psi line pressure that almost all injectors are flow tested at?
-Sly
Old Aug 9, 2004 | 09:21 PM
slow's Avatar
that rating is at 4 bar 58psi, they're really smaller than 24#'s on a conventional scale, something like 22.4 or so
Ryan
