Will i need to upgrade fuel pump???
Old Aug 20, 2004 | 08:16 AM
Raise's Avatar
Default Will i need to upgrade fuel pump???
i have a cam/bolt on 02 car right now with around 13k miles on it. i have stage 2 heads on the way that will probably put me at around 425 to the wheels. ive read that the stock fuel rails are good up to like 550 hp. i will probably go to bigger injectors down the road. i wanted to know about my fuel pump right now. should i upgrade my fuel pump while i have my stock injectors? how well does the stock pump flow, and what is a good aftermarket one to go with?
Old Aug 20, 2004 | 02:09 PM
AnthonyR's Avatar
You should be fine with your current power, but if you plan on going with nitrous or other power adder you will need injectors and or a fuel pump upgrade. Racetronix sells a great replacement pump, you can get it from Thunder Racing, they sell injectors too.
