Probably the dumbest question to date
Basicly i dont want more fuel than the computer decides to dumped in but if the motor need more fuel top end i want the supply to be there.
your wide open tune will be enriched however as your fuel trims will not be affecting them since they are negative thus zeroing at power enrichment.
you can also hook a manifold pressure reference to the stock regulator.. however that gets more tricky running a vaccum line inside the tank.. that would also help out his situation assuming he is forced induction.
in the long run bottom line is your stock regulator is cheap-o and undersized anyhow.. just put an external regulator under the car and be done with it (for a while
