LS1 Injectors in LT1??
Old Sep 5, 2004 | 07:15 PM
LS1racer346's Avatar
Default LS1 Injectors in LT1??
I have a 1998 Stock Ws6.. and a 1994 Z28 355CI, Ported and polished heads, Manley valves, 3 angle valve job, 1.6RRs, Cam, and Spring set.. The camaro has a bad miss under load.. my question is.. will the LS1 injectors work on the LT1? I might add the Camaro has stock Tune and injectors.
Old Sep 5, 2004 | 09:56 PM
Camaroholic's Avatar
Work? Yes. Be right without tweaknig? No.
LS1 fuel pressure is rated at ~4 bar (59 psi). LT1 fuel pressure is rated at ~3 bar (43.5 psi). So a 28 lb/hr @ 59 psi injector will spray significantly less at 43 psi. You'll either need to raise the fuel pressure on the LT1, or change the PCM for the scaling factor (probably to about 20-22 lb/hr).
Old Sep 5, 2004 | 10:31 PM
It is running like hell right now, trying to go from a dead stop .. you have to get it to around 2500RPMs then feather the clutch out or it missfires really bad, then sounds like its flooding itself out. the fuel economy is around 9mpg.. You can smell raw fuel under the hood when the car idles.. im thinking an injector is stuck open.. Originally thought the miss was opti.. changed that, wires, and coil.. As long as it will run better than it does now.. untill i can get the PCM done.. all is good.
Old Sep 6, 2004 | 07:54 AM
Well, sounds like it'd be worth a shot to try it out and see if the injectors change it. I don't think having them in 'short-term' will hurt anything. I've known guys to stick 20 lb/hr injectors in their LT1s with no ill effects (other than their LTrims going to 160 while the PCM tries to flow more fuel - but that's another story...).
Give it a try, I'd say, and see if your miss goes away. Have you checked fuel pressure?
