What fuel pumps are safe for use with E85?
Old Sep 8, 2004 | 08:22 PM
Cheatin' Chad's Avatar
Default What fuel pumps are safe for use with E85?
I'm at a loss here. Does anyone know if any of the "high performance" fuel pumps that work w/LS1 F-bodies are compatible w/ E85?
Old Sep 9, 2004 | 03:16 PM
LOnSLO's Avatar
You're goin to need something in the lines of a BG race pump. There isn't a pump that is a direct fit that will keep up with the amount of fuel you'll need.
Old Sep 9, 2004 | 03:46 PM
What's the flow rate of the pump offered on E85 Trucks with the 5.3?
My understanding is that it doesn't flow a drastically different amount of fuel than the gasoline only set-up.
Old Sep 10, 2004 | 10:43 AM
LOnSLO's Avatar
I think you're right. I was thinking the flow was more like an alcohol system, but it's way less. I would try and ask Aeromotive, and just see if their pumps are compatible.
