Best fuel system setup for 427
Old Sep 11, 2004 | 09:06 PM
11 Bravo's Avatar
Default Best fuel system setup for 427
I need some help deciding which pump and injectors I will need. I *may* run a smallish shot. No more then 200. I like the Racetronix pump, but I don't know if it is enough for me. Injectors? 42's enough?
Old Sep 11, 2004 | 11:33 PM
MECHAM's Avatar
play it safe...
dual intank 255's
60# mototrons
Old Sep 12, 2004 | 02:35 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
The Racetronix system is safe to 550-600RWHP depending on your BSFC.
This can be extended to 650-700RWHP with addition of a PnP booster.
http://www.racetronix.com/RX-F99-FPKG-2.html
If you are planning on a wet N2O system which does not require fuel being added through the injectors to support the N2O then 42's will be fine.
http://www.racetronix.com/Racetronix..._Sale-42s.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
