C5 fuel pump---it is a Walbro
Anyway, the actual electric pump is a Walbro. It says that right on the side. It is much heavier than a standard in tank pump.
It has two pick up points. One on the bottom that is heavily filtered and one inside the plastic tube where the pump is mounted. It is my understanding that this keeps the pump able to pick up fuel even on hard corners, etc. as that plastic housing stays wet. It is not nearly as well filtered though which I think is strange.
Anywho...just thought I would share.
BTW--I am thinking of slipping that pump in my 96 Caprice tank which I am fitting into the 69 Camaro at this time.
