What would I need for this set up?
Old Nov 1, 2004 | 07:40 PM
The Guy in MY 99TA's Avatar
Default What would I need for this set up?
I am in the process of gathering parts for a 408, iron block of coarse. I am gunna do an eagle rotating assembly, something like a 244/248 or 250 custom grind HYDRAULIC roller. I am seriously thinking about the AFR 225 heads and then disassembling them and go through them and massage them a little bit more. I'm gunna add some edelbrock stepped headers with some sort of cat-back( I have replaced most parts in teh exhaust just never did a cat back b/c I liked the resulting sound of the car). Top that off with an ls2 intake with a fast 90mm tb with custum rails and then I am thinking of adding 2 walbro 340 intanks to supply the fuel, which leads me to my main question.
What injectors would be sufficient for this set up? I am looking for power levels in excess of 500 at the rears. I was thinking a 40 lb or maybe 42's.
What do you guys think?
Josh S.
FWIW.... there will also be a stand alone fuel system with a direct port system to support a 300 shot or so.
Old Nov 3, 2004 | 10:56 AM
any1 wanna help?
