Do I Need a Fuel Pressure Regulator at the Rail
Old Nov 7, 2004 | 06:56 PM
mediumrareintx's Avatar
Question Do I Need a Fuel Pressure Regulator at the Rail
I just upgraded my ATI Procharger from 4psi to 7psi. I also removed the funky FMU, installed SVO 42 lb fuel injectors, and installed a Racetronic PNP in-tank fuel pump.
I know I need a tune. I think I'm going to purchase HPTuner for this.
My question is do I need to install a fuel rail fuel pressure regulator?
2002 camaro, Stock 350, ATI procharger 7psi intercooled, Racetronic fuel pump, svo 42 lb injectors, Irridium plugs, 180 thermostat
Old Nov 8, 2004 | 08:16 AM
Viper's Avatar
ttt - who makes a fuel rail fuel pressure regulator for us?
Old Nov 12, 2004 | 06:19 PM
Ping King's Avatar
if you wanted to do a custom foward mounted regulator...you would have to remove the intank regulator....have a return line from the regulator in the front...and just mount a standard fuel pressure regulator.
i did it with my car...its not really that hard...just plumbing.
many cars are using teh stock returnless fuel line setup with a standard 7 psi kit..so i dont think its that critical...but safety is always nice.
