STS Fuel Injector Size
Could be fuel delivery problems. (i.e. fuel pump) You'd need to check fuel pressure under load to be sure.
Might be a tuning issue? (PE set too low, since the pcm can't account for boost.)
You could probably upgrade to 30's, which are 20% bigger than 28.8's (which are really 24's at the same psi everyone else measures at). Or anywhere between 30 and 42. Prices are about the same in that range. Whatever your tuner is comfortable with setting up.
I went with 60's on my setup, but that was based on a 600-650rwhp target. Far as I know, that's the biggest that will idle ok (very short pulsewidths at idle) and that will still run on the stock pcm (high impedance) without a converter box.
Do you know what hp level you're shooting for? That's the most typical way to calculate back to an injector size.
no need to get just barely what you need and be stuck again.
now for a shameless plug
I will sell you my 42's for a good price as I am moving to 60'sPM me if interested.
