what size injectors
I don't know how much additional fuel you will need because of the SC combined to your actual setup.
Which injectors are you running right now? HP? Torque?
Does the powerdyne come with a FMU or a bigger fuel pump?
I persomally would go with bigger injectors (but not too big), then a whide band tune.
Fuel and boost gauges are a must (in my opinion). I have normally 62 PSI fuel pressure and 58PSI at WOT. My 36# Bosch are at the upper limit, for my setup it would be better to go a step higher: 38 or 42#
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
