Upgrading injectors require upgrading fuel pump?
Old Dec 5, 2004 | 02:10 PM
natesiy's Avatar
Default Upgrading injectors require upgrading fuel pump?
Just as the title says.
Do i HAVE to upgrade or add an aux fuel pump if i'm getting a set of 42lb/hr injectors?
Going to be running it in a stroked 5.3L to a 383 with an STS turbo.
Old Dec 6, 2004 | 02:43 AM
chris99gmc's Avatar
you might as well.. i would
Old Dec 13, 2004 | 05:49 PM
BigBlockChev572's Avatar
You don't have too, but the motor might run rough. Your buying bigger injectors to flow more fuel for the FI set-up, you'll definetely have to upgrade the fuel pump when you start adding boost with big injectors.
Philip S.
