Strange fuel pressure reading... key on/engine off. Help?
Old Dec 5, 2004 | 02:33 PM
Ed FvC's Avatar
Default Strange fuel pressure reading... key on/engine off. Help?
I've been having some issues with the car, where it's leaning out when going to WOT. After a week's worth of troubleshooting and ruling things out, it's now down to one of two things: fuel pump or injectors. The motor is stock, including all fuel systems.
Checking the fuel pressure today, and this came up... At idle, fuel pressure remained steady at 58-60psi. Trying a key on/engine off test, however, it jumped up to 55 and quickly dropped back down below 45psi.
From what I understand, this isn't right...but I have no idea why. Help?
Old Dec 6, 2004 | 01:09 AM
red90cobra's Avatar
Yes that's bout right. You have to have the car running to keep the fuel pressure up. The pump only bumps on for 2 seconds then turns off. Mine does the same thing. Have you changed your fuel filter?
Old Dec 6, 2004 | 08:16 AM
Ed FvC's Avatar
I know it's supposed to drop. However, it's not supposed to drop 10 psi in less than 10 seconds, and certainly not below 45 psi.
Yes, I changed my fuel filter.
Old Dec 7, 2004 | 09:19 PM
ArcticZee's Avatar
I am far from an expert, but maybe it could a bad check valve in your fuel pump that is causing the pressure to drop that much.
