What is max hp for stock 2000 pump
Old Dec 9, 2004 | 06:42 AM
AINT SKEERED's Avatar
Default What is max hp for stock 2000 pump
changing cams and dont know if I will have time to install 255 walbro pump also before going to track this Sunday. I already have 400 rwhp with teh 222 c1 cam, going to the f13 cam and just curious what the avrage max hp you can get away with for a short while.
Say I get 430 rwhp , will the stock pump support it for a little while( races on this sunday)?
Old Dec 9, 2004 | 01:26 PM
NLang's Avatar
I've been told 400rw is safe, and 450rw is as far as you want to push it. I know of a few 470rw (+/- a few) combo's with the factory pump and larger injectors. But, who's to say how long the pump will last. Just start saving and shopping around for a better pump as a replacement for when it burns up. Kind of like keeping a spare differential and/or gear set around for the tiny 10-bolt
I went with the Racetronix PNP kit. Not cheap, but it's a simple install WITH an upgraded wiring harness for the higher output pump (directly connects it to the battery ) Considering pumps are voltage sensative, VD from the skimpy factory wiring could cause problems. No 'fabbing' or cutting up anything with it either. Just something to consider...
Old Dec 11, 2004 | 12:43 AM
thanks , I already bought the walboro 255 but just not enough time to install it before Sunday. Going racing Sunday and just finished a fm13 cam install tonight but tomorrow is booked with the kids. I will only race it once with the new cam and stock fuel pump.
Old Dec 11, 2004 | 02:35 AM
NLang's Avatar
I wouldn't worry about it with such a short ragging
