injectors
2000TA=TR 224 CAM, LS6 INTAKE, COMP CROMEMOLY PUSHRODS, COMP 918 SPRINGS, SLP LT'S, ROLLMASTER 2X TIMMINGCHIAN, PORTED TB, PORTED MAF ENDS, LS6 PORTED OIL PUMP, LS1 MOTORSPORTS LID, SLP SMOOTH ELBO, FLOWMASTER CATBACK, CARSOUND CATS, NOS 5177 DRY KIT.
You can run the stock 26.6lb injectors up to 400rwhp. I am. But you should tweak the duty cycle to over-drive them or you will run lean. I have. (Note - 384rwhp = 450 crank hp for an M6 & 480 for an A4)
The proper way would be to increase your injectors (I am), ESPECIALLY if you are adding heads to your car. Go here to find a worksheet to determine inj requirements.
http://www.rceng.com/technical.htm#WORKSHEET
Lots of people run their inj at 100% duty cycle, or more. But all the 'experts' will tell you that anything over 80% is asking for trouble. Over heating the fuel, running out of fuel, running too lean.....all the bad stuff. According to the chart, your car should have 30lb injectors. But hey, it runs now right, so why worry?
