another tank will not fill
Parts put on:
fuel rails-speed inc
barded fuel line for crossover and from the metal fuel line to the driver side fuel rail
42lbs injectors
I did a search and the only thing that I could find was that the vapor valve thing should have been put back on, maybe?????
The fuel just comes out when you fill it. I have tried 3 different stations with the same results. tank is now empty so I really need to find a way to get some gas in the tank so that I can get it fixed back at the shop that did the fuel rails. If it the vapor return I hope the shop still has it lying around.
Edit: ok I did some more searches and want to add some info. Two weeks ago I had a walbro 255l intank pump put in. No problems, no codes. Now that the new fuel rail is in and the evap is off the evap line to the tank has a rubber vacum cap on it. I think this is my problem. The only solution to my current problem now is to take the rubber vacum cap off but then the garage will smell like fuel. Need better solution, any ideas?
Last edited by pushinfreight; Jan 30, 2005 at 01:40 AM. Reason: Did more searches I think I found my problem
The issue probably there as the filler neck and tank were removed to intall the pump and would really be my first thought.
Now, the Solenoid is definately the SES light, but that wont keep you from filling the tank.I do however recommend hookin it back up as it completly alters the low speed tuning.
Dave
Dave
