racetronix fuel system w/
Old Feb 6, 2005 | 10:31 AM
HellRaiser's Avatar
Default racetronix fuel system w/
I am trying to plan out my fuel system for my 99 TA. I am going to be putting the new phamspeed kit soon. But I want a fuel system that will grow witht the car not one that I have to change out because I wanna run more power. So heres what I am thinking racetronix fuel system new -8 feed line and use the factory feed line for the return. New fuel rails and fuel pressure reg. #60lb injectors. My goals are to run 500-600rwhp with the factory motor hopeing more on the high 500 side maybe running a meth injection kit to get more. But I wondering if this fuel kit would work once the motor is built and the boost is turned up to make 600-700rwhp? What do you guys think about this or should I just run the twin walbro's??
Old Feb 9, 2005 | 09:14 PM
98BlackTA's Avatar
The racetronix with the harness installed will get you pretty far. Then later ad a inline pump.
