Fuel setup advice?
Old Feb 6, 2005 | 08:56 PM
95maroman's Avatar
Default Fuel setup advice?
Building a turbo'ed ls1 from my 95 v6 fbody and wondering about the fuel system. Will a swap to a 97 vette fuel rail, in tank holley pump(rated 800hp) and 60 lb injectors be able to keep up with 650hp? Ofcourse i know it wont be peak performance but will it work decently?
Old Feb 8, 2005 | 08:33 AM
smokinHawk's Avatar
thats alot of power out of a V6. as im confused will it still be a V6 cause you said vette fuel rails, which has provisions for 8 injectors, unless a vette came with a V6?
anyways if it was a V8, turboed, the vette rails, and holley pump should support the 650 Crank HP, if going over 600rwhp, id get two intank pumps. with eight 60'lb injectors they should support 800rwhp.
if six injectors then id only trust them to 600rwhp
