Fuel pump removal
Old Feb 9, 2005 | 09:30 PM
98BlackTA's Avatar
Default Fuel pump removal
Allright, I had my friend install my racetronix pump while I was deployed he did the trap door method.when he put the pump back in he messed up my fuel sender in the process ,but he got the pump in. When I got back I decided to take it out and see if there was something I could fix but there wasnt and when I went to put it back in I must have done something to the fuel pressure regulator or put a hole in the return plus it was hard as hell to get the whole assembly back in. I have a 98 so I know its harder then the 99's and up. I found a whole fuelpump and sender on ebay. My question now is should I try the trap door method again or drop the tank. I just dont wont to f-up the new sender.
Old Feb 10, 2005 | 10:18 AM
onfire's Avatar
Coal Mining Director
I'd try the door since it's already cut. Just keep an eye on the removal and don't scrap anything on the door.
Old Feb 11, 2005 | 05:27 AM
72ChevelleConv.LS1's Avatar
Not sure what you are paying for the sender but I will sell you it for $75.00 pump and sending unit. just need to replace one flex line for the pump.
