Carb Manifold to Injection
Old Mar 1, 2005 | 06:02 AM
smokinHawk's Avatar
i can see no wipers with you setup ryan, but how about just with the intake and TB adapter? not the big carb type TB and air cleaner
Old Mar 1, 2005 | 12:34 PM
y2khawk's Avatar
yes, my motor is down and back. Only had to trim about 3/8" back into the metal of the cowl. Stock location it would probably clear the cowl.
But no way the hood would fit with it at stock height. Mine's only about 1/2" from the outer skin of the hood now.
wipers might still fit though
Old Mar 1, 2005 | 12:54 PM
99t66ls1's Avatar
Here are some pics of one we built that is for sale, we can make the elbow to any request, this one clears the stock hood and cowl.
https://ls1tech.com/forums/lsx-parts-sale/282822-custom-ls1-efi-intake-manifold-w-elbow-fuel-rails.html
Old Mar 1, 2005 | 08:14 PM
billybob77036's Avatar
Harlan, is that the GMPP intake, or the Edlebrock one or ??? ? Also, are there any 4500 mounting intakes made by anyone?
Old Mar 2, 2005 | 01:34 AM
y2khawk's Avatar
It's the GM one. I think both on the market are 4150 bolt patterns. There might be enough meat in the GM one to drill the other pattern, but I'll have to look at it to be sure.
You can always use an adapter/spacer plate. But then you'll definately not get it under the stock hood
Old Mar 2, 2005 | 09:57 AM
no way i'd go with a spacer. just trying to think of more ways to cram air in. thank you sir.
Old Mar 4, 2005 | 01:32 PM
GoldenVelvet's Avatar
https://ls1tech.com/forums/showthread.php?t=282822
That is EXACTLY what Im looking for. I just blew my mod money on a full suspension setup, but when I have funds again I will be contacting you.
I have a truck so clearance is never an issue. I would like a few vacuum ports though. Other then that its PERFECT. Keep the jigs handy.
