filter mount
Old Feb 19, 2005 | 05:17 PM
flippincamaro's Avatar
Default filter mount
where are you guys mounting the filters at for the fuel i have an inline pump and the filter was before the pump but my pump was starving for fuel whining real loud and that was the second pump so i took the filter off that was new and the pump is so quite and the fuel pressure stays the same. thanks for any help
Old Feb 19, 2005 | 06:49 PM
GTS346's Avatar
Filter should go after the pump, unless it is a prefilter which then can go before the pump, you dont want a filter restricting the pump as it causes it to work harder, over heat and premature failure.
Old Feb 19, 2005 | 08:28 PM
thanks that helped aot
Old Feb 22, 2005 | 02:23 AM
onebad427's Avatar
The other option is to run a large enough filter. You don't want your filter starving your engine either. Filtering before the pump if possible is a sure way to keep your high dollar aftermarket pump in tip top shape. I run a #10(1/2") fitting out of my tank into a high volume, #10 on both ends, filter y'd into two hungry pumps with #8(7/16") fittings and line y'd back to a #8 fitting and line up to my fuel rails. This feeds a supercharged 427 with #60 injectors. Goodluck.
