Are stock injectors enough?
I also have a NX 150 shot (wet kit). possible rwhp ~ 550
The previous owner states that the injectors are stock (28.8#).
I feel comfortable w/ the stock injectors as long as I don't use the nitrous.
Does anyone think I should upgrade the injectors to maximize the nitrous? Is there any danger to the motor if I use the nitrous and don't upgrade the injectors?
EDIT: And if the injectors are stock, and the car is a 98, then the injectors are only 24lbs I think? They aren't 28lbs, those were only used on the 01-02's.
(I plan on upgrading anyway, I'm just waiting for the cash.....
) (I plan on upgrading anyway, I'm just waiting for the cash.....
You may have just saved me lots of $$$$
I'll sheck into the inline pump and possibly some 42# injectors. Better to be safe than sorry
I definately would not run the nitrous as it is, the fuel demand will cause the fuel pressure to drop, resulting in a possible lean condition and damage to the engine.
You should be fine on motor, stock fuel pump should be fine till you get close to 500rw, your inj should be fine to around 425-450ish
