Wiring Bosch 420
use the factory grey power wire and send the other side to frame ground OR use the wire harness. i would use a relay with fresh alternator power.
i guess you are sumping your tank?
Thats what i did..... i was told that the 420L was to much pump and would burn out the stock relay..... so i added a bigger one..... so the stocker clicks on the new relay wich in turn powers on the pump..... Ill be running 2 Bousch 420L with my new setup.......
Kyle
