LS1 fuel system: How much can it support?
I try to check the problem to here:
http://www.rceng.com/technical.htm
so, I try to calc the injector size for 500 FWHP.
fuel rail pressure is about 50PSI (checked in 1998 GM service manual)
I filled the fuel injector worksheet:
Actual Desired HP : 500 FWHP
Num of Inj: 8
BSFC = 0.5 (no turbo/charger)
MIDC = 0.8
System fuel pressure/fuel rail = 50PSI (48-55PSI)
inj. req 36.44
so max bhp with #30 injectors : ~ 400 FWHP (~350 RWHP) (calculated with this calculator)
Is this a correct calculation? but lots of ppl say, stock 26/28 injs.are enought for 500RWHP (about 580-620 FWHP). I don't understand this...
thanks for help
You are correct. The 28's will not support that kind of HP.
I'd like to see their logic behind this statement.
I maintained alot of stock injectors for the now defunct, ASA stock car racing program. We ran the FP at 60psi, and found they would support approx 480 FWHP. [LS-1 spec engines.]
