Need some fuel pump help
I think the pump is going bad now.
1. Have to be cranking to get pressure to the rails.
2. Turn key on the pressure goes from 0 to 15 then falls off to 0.
3. Under WOT a few seconds under load and its like the fuel pump just shuts off, car falls on its face and pops then dies. hit the key the car starts right back up and runs fine until WOT.
The questions, if it had the Walbro 340xp can I just swap in the Racetronix with hotwire kit in or do you think the basket was modified for the Walbro? Also will the Racetronix support my 427 with 38# injectors when I hit it with a 150shot?
Thanks for the help.
Josh
