how much hp for stock pump
Old Mar 14, 2005 | 03:25 PM
98sspullin'em's Avatar
Default how much hp for stock pump
i was wondering how much hp a stock in-tank fuel pump can support?? and at what hp would i need to upgrad from my 28 lb injectors?? i did a search but they were all for spray or boost, this is going to be n/a?? and if so which ones should i go with becuase i know the walbro you have to modify?? around 500 fly wheel hp?? thanks for any help! dwayne
Old Mar 14, 2005 | 04:58 PM
1FASTLS's Avatar
I think I saw in several threads 485hp not sure, but I know the new c5 vett has the same pump and their 500hp rated, if your not going to crazy install a inline,injectors all depends on your mods but her is a site that may help you with your pump issue good luck,
http://www.public.asu.edu/~nicolasd/...mpinstall.html
Old Mar 14, 2005 | 07:56 PM
snake charmer's Avatar
It seems that I have read the entire full system(rails,pump,injectors), would be good to about 500hp. Not sure of the direct threads off hand maybe someone else can chime in.
Old Mar 17, 2005 | 06:37 AM
Shoulder Shaker's Avatar
When you say modify are you speaking about the walbro 340 have to be modified at 500hp or are you saying the 340 have to be modified to be installed?
Old Mar 18, 2005 | 12:30 PM
the walbro 255 we had to modify, i think it was the 255...???
