Fuel system help
Old Mar 16, 2005 | 06:58 PM
CoopDog's Avatar
Default Fuel system help
I have looked all over, used the search and am more unsure about my fuel system. I have a 99 z.
I have a forged 360 with a Vortech T-Trim that will run at 13 Lbs boost-for sake of argument. I figure 575 Hp, 600 if I'm really lucky.
My fuel system consists of a 255lph intank pump with boosta pump and 50lb injectors. Everything else is stock. Would this be sufficient, borderline or not enough. I'd rather over fuel than not enough.
I was thinking of building a system, using an external pump, new rails etc. Would the stock tank not be up to the task, considering that it is not baffled? If I remove the stock type pump, would I lose the gas guage.
If I build a system, are there any FAQ's, diagrams and pictures anywhere?
Old Mar 20, 2005 | 04:52 PM
CoopDog's Avatar
Anyone?....Bueler.....?
Old Mar 20, 2005 | 10:42 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Stock pcm John?
If so, I let's think about this, would you be shooting for 600-650rwhp?
I wonder if you would be better off with 60 lb Mototron injectors. As for as the fuel pump stuff goes, I'm not really sure.
Old Mar 20, 2005 | 10:47 PM
onfire's Avatar
Coal Mining Director
What brand 50 lb injectors? 42lb Bosch (which is 50lb at 58psi) will go 620rwhp easily.
I'd just check the A/F on a dynojet for insurance, but your system is fine for 600-650rwhp.
Old Mar 21, 2005 | 07:45 PM
CoopDog's Avatar
The injectors are Delphi, I believe. I did get the 50's thinking they would be sufficient, after doing some research. I thought that 50's would be a little bit overkill. I could be wrong though. I want to set something up now that I won't have to replace later.
My current thinking is to do a bulkhead connection to the plastic tank and go from there. I would be somewhat worried about the lack of baffleing in the plastic tanks at that point.
Mechanically, I have no problem with doing this system. I could however, use some info as far as the design of a system for my application.
I'd rather make a good aftermarket fuel system rather than worry about the stock components not being up to the task.
Thanks for the input guys, I need all that I can get!
Old Mar 21, 2005 | 07:50 PM
onfire's Avatar
My fuel system: 600rwhp Single walbro,KB, 42lb Bosch stock lines,rails, removed stock regulator and installed a reg at the filter in the return line.......plenty of fuel dyno tested.......If you're staying under 650rwhp anything else is a waste.....over 650 get the wallet out.
Old Mar 21, 2005 | 08:10 PM
CoopDog's Avatar
Hmm, maybe I'll stick with what I have then. I don't think I will be anywhere near 650.........unfortunately.
