delphi 50#
Old Apr 1, 2005 | 10:29 PM
Moparnos (The SLP Guy)'s Avatar
Flossin' twin turbos
Default delphi 50#
does anyone have the specs on these like flow rating and fuel pressure? thanks
Old Apr 2, 2005 | 12:54 AM
tryintogofast's Avatar
TADA all from racetronix.com
Static Flow Rate: 50.0 lb/hr @ 43.5PSI (300kPa) 525cc/min or 6.4gm/sec
Static Flow Rate: 57.7 lb/hr @ 58.0PSI (400kPa) 606cc/min or 7.4gm/sec
Dynamic Flow Rate: 1.1 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 43.5PSI (300KPa)
Dynamic Flow Rate: 1.3 gm/pulse - 2.5ms pulse width and 10ms repetition rate @ 58.0PSI (400KPa)
Coil Resistance: 12 Ohms / High Impedance / High-Z (No ECM driver modifications required)
Cone Spray Angle - 22.4 degrees - single spray cone. Approximate cone angle for 90% of spray volume
