Z06 Injectors - flow rate?
Static Flow Rate @ 43.5PSI (300kPa) = 28 lb/hr (294cc/min)
Static Flow Rate @ 58PSI (400kPa) = 32 lb/hr (336cc/min)
for the Z06 injector, GM part # 12561462.
I always thought the Z06 injector was 28.5 lbs/hr for our cars?
Is it 28 or 32?
I ask because I contemplated moving up to SVO 30 ( which are really 36 lb/hr in our fuel system ) with my new combo thinking the 28.5 wouldn't be enough. Granted, the plan is to atap it to find out if what I have now is enough.
But if they are truly 32 lb/hr in our fuel system, that sounds fine for my power levels.
corvette fuel rails. Not sure what the camaro or firebird operate at.
Is it 28 or 32?
