Torco Fuel additive
Old Apr 9, 2005 | 09:07 AM
badass 2002 z28's Avatar
Default Torco Fuel additive
Anyone here use this stuff? supposed to actually work and add up 10 points to ur fuels octane (like from 94 to 104) depending on how much you mix it with.
http://www.torcoracefuels.com/catalo...products_id=28
Old Apr 9, 2005 | 09:20 AM
SDB's Avatar
SDB
I run this in my Camaro with 93 octane and a 200 wet shot....works great, no KR on the dyno with 2 degrees of timing out. I put one bottle per tank or 1/2 tank....fairly cheap and easy way to run good gas...I get it for about $10/bottle through a local shop.
go to www.corvetteforum.com and go to C5 section, and then go to supercharger/forcedinduction/nitrous section and research Torco there...
SDB
Old Apr 9, 2005 | 08:17 PM
critter's Avatar
I've used it to kill KR caused by running too much compression on 93 gas.
