Injector response time?
Old Apr 18, 2005 | 10:40 AM
JNorris's Avatar
Moderator
Default Injector response time?
Do the 30# SVO injectors open faster or slower than the stock GM 28.8 lb injectors found on the 98 LS1s?
Thanks
John
Old Apr 18, 2005 | 02:00 PM
SSpeedracer's Avatar
This is a good question that is rarely addressed. I asked racetronix a similar question regarding the lucas 42#, but didnt really get a response.
I am certain that lucas, delphi, bosch, etc have opening time/closing time OT/CT data on their injectors. All the OEM's demand that data as tested per SAE J1832. Flow range and spray pattern would be nice know also.
Old Apr 22, 2005 | 07:13 AM
JNorris's Avatar
Moderator
To the top
Someone has to know this.
Old Apr 24, 2005 | 01:06 AM
pekkaz's Avatar
It seems to be fairly close to the same. Slower and faster depending on voltage...
Scroll down until NoGo's suggested offset scaling. I used it against the '98 table and ltfts fell better in place.
https://ls1tech.com/forums/pcm-diagnostics-tuning/105390-42lb-bosch-svo-injectors.html
Old Apr 24, 2005 | 01:26 PM
wrencher's Avatar
wrencher
It is dependant upon alot of factors. the mechanical injector the coil resistance, the voltage the fuel pressure, & alot of other things I couldn't dream up. There are some complicated formulas out there used to caculate the OEM's offsets.
Old Apr 26, 2005 | 09:13 PM
JNorris's Avatar
Moderator
https://ls1tech.com/forums/showthread.php?t=105390
Thanks for the info.
