Racetronix fuel systems
Old Apr 22, 2005 | 06:02 PM
Krazyrat99TA's Avatar
Default Racetronix fuel systems
alright guys its time for a new fuel pump mine is screwed...........i had a question bout the racetronicx fuel system that thunderracing has to offer part number 135-F98-FPK2 would this be a good replacement for a pretty much stock car........and what kind of gas tank do i have plastic or metal ?its a 99 trans am ......and is it necessary to go ahead and buy the Racetronix Series II Plug & Play Wiring Harness part number 135-F99-FPWHG-2 if it is indeed that it is a good idea to buy this system as a replacement of the stock system??????????????help me out guys prom is a week away and i need to get my car fixed hahahaha...........basicallly what im asking if it will be ok to buy the racetronix fuel system part number135-F98-FPK2 and the plug and play wiring harness part number 135-F99-FPWHG-2 to fix my car ?????????? your help is greatly appreciated thanks
Old Apr 22, 2005 | 06:08 PM
02SOMWS6's Avatar
You have a plastic tank.The guy's at thunder can answer all your questions ,so call and order it.Save yourself some time and do the trap door mod. That is cutting a hole in the floor of your hatch so you don't have to drop your exhaust,rear ,and tank. It will save you a ton of time if your gonna do it yourself. Get the complete plug and play kit. You wont be sorry
Old Apr 22, 2005 | 06:37 PM
ss rally red's Avatar
This is the way to go,especially if you continue to mod the car,the pump can keep up. I might be in the minority but I dont believe in the trap door mod for a couple reasons. If its not a race car why butcher the interior where you cant go back,but more important and since I repair cars for a living, when I install a new fuel pump I want to make sure the tank has no contaminets in in and the only way to be sure is to drop the tank and clean it out,the fastest way to fubar a new pump is to let it suck up crap in the tank right away,hell my drop in Racetronics pump only took 2.5 hrs from start to finish doing it the right way.
Old Apr 22, 2005 | 08:22 PM
superchannelkev's Avatar
i dropped the tank as well and it was no biggie
Old Apr 22, 2005 | 08:30 PM
awesome thanks a lot guys
Old Apr 22, 2005 | 10:04 PM
LawmanSS's Avatar
I dropped the tank as well...it was not necessary for me to drop the rear end...I drained the tank, dropped the cat-back, upper and lower PHBs and it came out fairly easy. It was nice to be able to clean the sediment out of the tank before installing the new pump...
Old Apr 23, 2005 | 05:38 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Amen to that!
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
