No fuel
Old Apr 27, 2005 | 09:41 AM
Y2kforgedSS's Avatar
Arrow No fuel
Ok im having a problem, i was driving home last night and when i was half a mile away from the girlfriends house the car just dies. So i sit there and check all guages to make sure everything is cool and then try to start it again but no luck. It wants to start its just i checked the fuel rail and there is no fuel in the rail. I just had a brand new walbro 340 pump installed and a new fuel sump. What could be my problems and how can i fix them?
Old Apr 28, 2005 | 12:55 PM
Is someone going to pitch in or just read it?
Old Apr 28, 2005 | 01:16 PM
MrDude_1's Avatar
same as every other time you troubleshoot the fuel system.
1. check the relay.
2. if the relay is working, or bypassing doesnt fix it, check for power going to the tank plug.
3. if the tank plug has power, you'll have to assume that:
  1. the pump is bad. not likely cause its new.
  2. the connector to the pump fell off inside the tank. or some other oddball wiring mishap
because you JUST worked on the pump, my guess would be 3b if its not the relay.
Old Apr 28, 2005 | 05:09 PM
could you tell me exactly were the relay is, i know its in the fuse box under the hood i just dont have the stickers to tell where its at anymore. And how do u bypass the relay?
Thanx
josh
Old Apr 29, 2005 | 03:53 PM
? hello
Old Apr 29, 2005 | 06:42 PM
jay_99z's Avatar
this is MrDude_1 on a friends PC...
heres the layout of the fuses/relays.... you're just lucky i thought of it when we were snapping pics of ja's new WS6 vert
Old Apr 29, 2005 | 06:58 PM
onfire's Avatar
Coal Mining Director
Can you hear the pump cycle when you turn the key? I bet the pumps bad or the line came off the pump.
