Fuel pump Question
Old Apr 28, 2005 | 10:23 PM
LS1-STen's Avatar
Default Fuel pump Question
I'm installing a racetronix pump and wiring. With my set-up I don't need the small line that comes off of the pump. Do I cap it off or do I leave it open?
thanks.
Old Apr 29, 2005 | 06:39 PM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
thanks.
You must cap it off.
Why did you order this system if you did not need the venturi feed?
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old Apr 30, 2005 | 07:39 AM
LS1-STen's Avatar
Actually we are going to convert it back to the stock set up with foam in the tank. I went to the Racetronix site and read up on how the system is supposed to work and decided that this is best for our set up. Thanks for the prompt reply as always.
