high or low impedence injectors?
Old Nov 4, 2005 | 08:22 AM
  #61
ddnspider's Avatar
when i test fit the set on my car the connector clipped right in and popped right in the intake,and the flow chart that came with them showed them as 60# HI Z injectors.....
Old Nov 4, 2005 | 06:45 PM
  #62
DeltaT's Avatar
Thank you for pointing out that I re-filed my question.
My point was I've seen a lot of "information" above on these Venom injectors but much of it seems to be completely wrong.
I'd hate to see people buying something and not being able to use it.
My points to help the community are:
1. Venom can NOT make any injector in hi or lo impedance. Up to 48lb/hr is hi. Above that is low. LSx cars can't use low impedance.
2. The Venom injectors advertised won't fit the LSx motors the way they are sold.
Is that helpful to the community?
Regards,
Jim
Old Nov 5, 2005 | 12:17 AM
  #63
69firebird's Avatar
how is it they will not fit LSx motors?
I have them in my GMPP intake, have had them on an ls6 that i am no longer using.
just trying to figure out how you are saying they are different
ed
Old Nov 5, 2005 | 12:57 AM
  #64
DeltaT's Avatar
Did you have to switch o-rings?
Which GMPP intake do you have?
Jim
Old Nov 5, 2005 | 01:22 AM
  #65
DeltaT's Avatar
This is an LSx injector:
This is a Bosch-style EV1 injector that fits a lot of other Chevys, like my LT4:
Jim
Old Nov 5, 2005 | 09:20 AM
  #66
69firebird's Avatar
DeltaT,
I understand what you are saying with the two different styles now that I see, I never really thought about it, but when you put them side by side I understand what you are saying.
HOwever ive put both injectors directly in each manifold. They were both snug, look how many people have used the ford 42lb green tops. they are the same style as the EV1's and work in the cars.
Im more worried about the quality of the injector than I am the style
Old Nov 5, 2005 | 10:30 AM
  #67
ddnspider's Avatar
they fit fine in my LS6 intake and the connector clipped right in.And the company that was a distributor with Venom on ebay,all u had to do was tell them what #/hr you wanted and if you wanted hi or low Z.And YES you can run a low Z injector you just either have to use an aftermarket controller or you get a converter....matter a fact ive got the price sheets for everything on Venoms website and that includes the injectors which has all sorts of #/hrs and high or low Z.I dunno why ur trying to argue,its been proven they fit and you can run low Z injectors as well,besides you cant even find them on their anymore can you?i havent seen any....
edit i found a few sets but they sure are expensive!
Old Nov 5, 2005 | 12:09 PM
  #68
69firebird's Avatar
just to be certain there is no confusion, you cannot run low Z injectors without either the driver or an after market fuel computer.
if you use low z and just plug them in it will work, however it will short out your computer after a while, do not use them without the driver or after market comp
Old Nov 5, 2005 | 02:29 PM
  #69
ddnspider's Avatar
what i said
Old Nov 5, 2005 | 04:08 PM
  #70
69firebird's Avatar
what i said
I understand its what you said, int eh first part of your post, and then didnt mention it later, I know you understood what you were saying, I just wanted to make sure everyone did
NO foul
Old Nov 5, 2005 | 04:39 PM
  #71
ddnspider's Avatar
no no i didnt have an attitude i was agreeing with you no biggie
