2 Questions
Old May 2, 2005 | 11:08 PM
SS LeadFoot's Avatar
Default 2 Questions
What injectors are good to run with a D-1SC kit with 8# and do you have to drop the rear to get the fuel pump in?
Will an injector like this work?
Injector type - EV1 SVO green
Impedance - 11-18 ohms
Flow Rate - 42 lbs/hr
Thanks
Old May 3, 2005 | 07:24 AM
onfire's Avatar
Coal Mining Director
That's a great injector for your project. You can drop the rear and remove the tank for the pump install (not hard to do). Some are cutting a door in the panel above the tank for pump access....must be careful as you can cut into the tank....some worry about gas fumes while cutting.
