minimum pulsewidth measured
http://para.noid.org/~lj/InjectorPulseTest.jpg
I've only looked at three part numbers so far, all made by Siemens-Deka, and all tested at 43 psi fuel pressure. Here's what I found:
60 lb/hr high impedance: 1.5 ms (this injector has a "Mototron" part number in ink)
72 lb/hr low impedance: 0.8 ms
83 lb/hr low impedance: 0.9 ms
As expected, the high impedance injector had a fairly broad transition from no flow at all to a reasonable stream, whereas the low impedance injectors had a sharper cutoff. I'm convinced that is why guys have a hard time getting the big high impedance injectors to work well at low loads.
Your values for 60's are very close to some I have for those injectors as well.
I don't know why people have trouble making them work, I use them for fords all the time with no real issues, but I have full batt comp tables as well.
Ryan
BTW, CHarris, do your injectors say Mototron on the body? Or Motron?
