ok heres a question........
Old May 8, 2005 | 11:44 PM
SSLS1's Avatar
Default ok heres a question........
ok so i have a msd 43gph in line fuel pump, so heres my questions should i install the inline pump along with the stock one?? or should i install the pump and wire it to olny come on when i activate my nitrous?? or what exactly should i do???
Old May 9, 2005 | 08:32 AM
onfire's Avatar
Coal Mining Director
I'd sell it and install an intank Racetronic pump. Clean install and safe. If you have to use it the easiest install would be to install it to run all of the time with your stock pump inplace running also. Then check the A/F on a dyno with and without the nitrous. Relays are ok but this way you don't rely on one. The stock pump flowing into another pump will allow the stock pump to flow much more volume.
Old May 9, 2005 | 01:28 PM
SSLS1's Avatar
ok so it wont hurt anyhting to run both the stock pump and the inline pump at the same time together all the time??
Old May 9, 2005 | 03:05 PM
onfire's Avatar
No problems....I've done it before.
