Walbro 340M to 340 replacement - Problems?
Old May 9, 2005 | 02:41 PM
NoGo's Avatar
Default Walbro 340M to 340 replacement - Problems?
Hello,
I run the old racetronix duel Walbro intank, 2 GSS340M pumps. It worked well for a few years, but one pump has decided to call it quits. I need to replace the pump, but Walbro discontinued the GSS340M pump and now only provides the GSS340 with a slightly different inlet.
Can I replace the GSS340M pump with the normal GSS340 without any problems? Has anybody done this and lived to tell about it? Do I need to purchase or modify anything to get the normal-style GSS340 to work in place of the GSS340M?
Any insight before I go diving into my fuel system again would be appreciated.
Thanks,
Kevin
Old May 9, 2005 | 08:52 PM
John_D.'s Avatar
I haven't done it, but I would toss out there, that you might ought to go ahead and do both of them at the same time... Just something to think about.
Old May 10, 2005 | 10:50 PM
Mike @ New Era's Avatar
The only difference between the two is the diameter on the inlet , which means you will just need the correct filter socks for each pump . We have plenty of them in stock if you want to upgrade both pumps to the gss340 with the right filter socks or even just one .
Mike
www.neweraperformanceparts.com
sales@neweraperformanceparts.com
585-865-1832
Old May 14, 2005 | 10:24 PM
NoGo's Avatar
Thanks for the heads up.
-Kevin
Old May 16, 2005 | 03:09 AM
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by NoGo
Hello,
Thanks,
Kevin
We have GSS340M's on the shelf. So does Thunder Racing and a few other Racetronix dealers.
http://www.racetronix.com/F20000169vs340.html
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old May 17, 2005 | 02:59 PM
mike s.'s Avatar
Does anyone know what the part # for the 255 lph sock that goes on the end of the Walbro pump? A generic parts house part # would be convenient too.
Dont mean to hijack!!
Old May 17, 2005 | 04:41 PM
Racetronix's Avatar
LS1TECH Sponsor
It is not a common part. Walbro pumps must have a 30 micron filter sock!
Thunder Racing has these in stock as well.
__________________
>WEB SITE<
