fuel pump booster
Old May 24, 2005 | 12:18 PM
  #41
Racetronix's Avatar
LS1TECH Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
Originally Posted by Wet 1
I definatly do not have a plug on this brand new MSD BAP that will interface with the plug in your picture... just bare wires. Is this thing used and repackaged I wonder?
"This connector set is installed on the booster wiring."
Obviously you are missing this extra connector set that came the Racetronix harness. Call Thunder Racing as they have spares in stock.
__________________
Manufacturer / Distributor of Automotive Fuel Systems, Components & Electronics
Please support a Racetronix dealer near you for personalized service.
>WEB SITE<
Old May 24, 2005 | 05:29 PM
  #42
kp's Avatar
kp
The MSD BAP I have is turned ~50% of the way to get 17v @ 10psi. Only think I dont like is at idle with vacuum the voltage is ~15.4v and I hope that wont overheat the pump after cruising a while. I was under the impression with no boost the voltage should be ~14v but its not so I may have a bad box. I e-mailed MSD but never heard back, I'll have to call them when I get some time.
Old May 24, 2005 | 05:34 PM
  #43
Racetronix's Avatar
LS1TECH Sponsor
Did you measure this voltage with a load / the pump connected?
Are you sure the MSD BAP is seeing vacuum? Does the voltage go down under 100KPa? The voltage won't hurt the pump but it will heat the fuel a bit more which should be avoided if possible.
__________________
>WEB SITE<
Old May 24, 2005 | 08:02 PM
  #44
kp's Avatar
kp
thats 'hooked to the pump' voltage, it definately has full vacuum at idle, its hooked to the same line my boost gauge is hooked to. With no vacuum its at 16v, when I pump 15in/hg with the vacuum pump it drops to ~15.5, when I pump 10psi into it it goes to a little over 17v the way its set.
Old May 26, 2005 | 08:30 PM
  #45
Wet 1's Avatar
Got you now. I called TR, Doug is getting one out to me ASAP... great service!
Thanks for your help!
BTW, any idea where that plug should be located on the installed harness on the C5?
Old May 26, 2005 | 11:11 PM
  #46
highspeedspecialist's Avatar
Can anyone tell me what is the venturi setup on racetronix pump? I just want to know what am I loosing if I got with the twin walbro setup.
Old May 27, 2005 | 03:49 AM
  #47
Racetronix's Avatar
LS1TECH Sponsor
It's all covered in our tech note here:
http://www.racetronix.com/RX-F99-FPKG-2.html
You can go quite far with a single system if it is done right. Thunder Racing and a few other forum sponsors have them in stock. A dealers few sell boosters as well.
__________________
>WEB SITE<
Old May 27, 2005 | 03:53 AM
  #48
Racetronix's Avatar
LS1TECH Sponsor
The plug is just after the relay. It is the same place the power lead is plugged for the drainage kit. The relay and booster should be mounted under the wheel well cover in front of the driver's side tire. There is a large open space in there and an existing ground location.
__________________
>WEB SITE<
Old May 27, 2005 | 03:57 AM
  #49
Racetronix's Avatar
LS1TECH Sponsor
Hmmm.... that is a bit high. Maybe the MSD unit does not drop voltage under vacuum and it only responds to boost?
You could always use Blowerworks Super Fueler for better voltage control. We will look into what can be done with the MSD unit.
__________________
>WEB SITE<
Old May 27, 2005 | 09:21 AM
  #50
kp's Avatar
kp
I actually had one of those turbofuelers five years ago, it came along with a carrol/votrtech C5 supercharger. It came with a 2 bar MAP and an inline fuel pump - thing was like 1500.00 though and didnt work all that well but it looked cool
My fear is the pump is overheating with the MSD. I have had no luck getting an answer from them on it and its possible its a defective unit. Under vacuum the voltage does drop slightly but its nowhere near what they say it is in their chart. If I drive the car for a 1/2 hour the pressure drops a little and it wont keep up at WOT, if I let the car sit a while it has plenty of fuel for one pass. I am moving the regulator up front and if that doesnt help I'll just rig up a dual in-tank 255 setup..
