what fuel set up for t76
Old May 22, 2005 | 12:11 AM
StoleIt's Avatar
NKAWTG...N
Default what fuel set up for t76
just wanna check over to see what everyone else suggests or is running. i dont want to spend 1k for a race set up. I'll be getting 42lb injectors and I'm planning on a pump, the question is which pump. I wont be boosting much (5-7). Any suggestions on a nice reliable (preferably easy to install) pump? And I should be able to keep stock rails correct? The car is an 02.
Old May 22, 2005 | 12:30 AM
Deamon2002's Avatar
I just got the Racetronix, but was suggested a Walbro 340, either way you need to go a Walbro 255 or larger, IMO. the reason I went with the Racetronix is because it has a harness, is plugg and play, and can have an overdriver installed pretty easily.
Old May 22, 2005 | 01:32 AM
CAT3's Avatar
Restricted User
For that low of boost, yes you can run stock rails, and line, upgraded injectors to 42, or look at some 50 or 60s. An intank walbro (or go for Racetronix using the Walbro pump) will fit your needs quite well, and a voltage booster would be a good idea also.
Old May 22, 2005 | 09:45 AM
MIGHTYMOUSE's Avatar
you need a f/p pressure gauge to see if your regulator is holding or not..
you would be ok with one walbro pump until 550rwhp or so
Old May 22, 2005 | 05:24 PM
StoleIt's Avatar
NKAWTG...N
sweet sounds good, thanks! any need for a fuel pressure regulator?
Old May 23, 2005 | 12:21 AM
CAT3's Avatar
Restricted User
I am ordering an Aeromotive...A1000-6, P/N 13109 It has 2ea -6 inlets (will run one from each rail) 1ea -6 return (to mount to the stock fuel rail once cut and sleeved) 1ea gauge port 1/8th NPT, 1:1 Boost reference, 30-70 psi base press so its compatible with our stock fuel pressure.
