Fuel Pump/Injector ?
Old May 23, 2005 | 09:42 AM
SheDevlLS1's Avatar
Default Fuel Pump/Injector ?
I have an 02 Z28, and this month will finally get around to putting more goodies on My question is this: What size fuel pump will I need for my setup, and are my stock injectors going to be enough? I'll be going with a 230/232 on a 112 cam and a small shot of gas
TIA
TJ
Old May 23, 2005 | 10:17 AM
ls1charged's Avatar
unless ur making more than 420ish you dont NEED injectors,if your spraying making more than 500 you might consider it
Old May 23, 2005 | 11:57 AM
ABeasst's Avatar
Walbro 255 hooche and no injectors
Old May 23, 2005 | 12:01 PM
SheDevlLS1's Avatar
You didnt see this post, Mr Iron Block.
The cam alone should get me 420-430 at the wheels (to the cynical, yes it will, do some research) and with the gas I'm looking for around 500, no more than 525. Still no injectors?
Old May 23, 2005 | 05:04 PM
ABeasst's Avatar
you'll be alright since its a wet kit....just get a 255
