Quiet PUMP
thanks guys
Install is REAL easy if you cut an access panel out to remove the pump.
J
An intank pump will be easier to install than an inline because its just a direct replacement. I went with Racetronix also. It is pretty quiet, louder than stock but you can only hear it when you prime the pump before starting. Easy install too with the trap door. Mine took about two hours to complete.
