How Do I Change My Fuel Pump?
Old Jun 16, 2005 | 08:33 AM
Bryan @ Speed Inc.'s Avatar
Default How Do I Change My Fuel Pump?
i have '99 camaro... I know i need to drop the tank, but that's about it. is there a site where i can get a write up on it?
Old Jun 16, 2005 | 08:40 PM
mrbobo's Avatar
I just finished doing mine...
put rear on jackstands, remove driver rear tire
remove driver inner fender plastic piece (1 bolt, 1 plastic plug)
remove gas tank filler plate (outside)(2 screws), then 1 bolt inside fenderwell to the filler neck
remove exhaust, from piece that goes over the axle to the tailpipes
remove both heat shields
remove 3 bolts on driver side of track arm, them just move the arm down
unplug the fuel lines, electrical going to fuel pump
use an 8" extension to remove 2 bolts that hold the fuel tank straps up
wiggle the tank out
from there, it depends what you wanna do for a pump. I used Racetronix F99 fuel pump kit, and their harness. Follow their directions, they are good, with lots of pictures.
Old Jun 16, 2005 | 09:37 PM
Ferocity02's Avatar
Or do this...
Cut hole in sheet metal above tank
Replace old pump with new one
Old Jun 17, 2005 | 03:52 PM
mrbobo's Avatar
Originally Posted by Ferocity02
Or do this...
Unless your a moron who punctured their tank, and had to remove/replace it anyways
