Advice needed on Injectors/pump
Old Jun 16, 2005 | 11:48 PM
ZYAL8ER's Avatar
Default Advice needed on Injectors/pump
Hey everyone, I just recently finished up my 98 Z28 and need some advice on what I should use for the fuel system. I have some racetronix 37# injectors laying around that I can use, as well as a 255lph walbro pump. I will be getting a mail-order tune after the fuel setup is complete. Do you think i need to use the new pump with my mods, or can i just use the injectors with a tune? Mods are listed in my sig. Any help is greatly appreciated.
Old Jun 17, 2005 | 09:16 AM
Dustin's Avatar
Definitely swap pumps and you might need some bigger injectors, stock with a 100 shot i was overloading with 110% stock 25lb injectors and with all of your mods I think you would need 42lb or larger injectors.
