Bad 02's?
Old Jun 21, 2005 | 02:09 PM
ONEBADWS6's Avatar
Default Bad 02's?
O.K here is the problem, the car is not throwing any codes and drives fine around town. But under WOT it bucks bad. I thought I was just spinning and hooking on the street but I took it to the track and the first pass I was down 10mph. Fuel and oil pressure is consistent and everthing looked good. So I made one more pass, which was .3 faster and 2mph faster. These are the original 02's from 99 in the car. I was thinking that they are fouled out and that after I did a WOT blast to clean them out some that is why the car went faster. Also I am running leaded racing fuel. Opinions?
Old Jun 21, 2005 | 03:15 PM
highspeedspecialist's Avatar
well the leaded fuel for sure will ding those o2s...
Old Jun 21, 2005 | 03:20 PM
btw under wot it goes into open loop ignoring 02s...
Old Jun 22, 2005 | 08:17 AM
ONEBADWS6's Avatar
Thanks, found a faulty plug wire.
Old Jun 22, 2005 | 10:24 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Can't run leaded gas and still use front 02's. After half a tank the 02 sensors will become sluggish.
Old Jun 22, 2005 | 11:28 AM
ONEBADWS6's Avatar
I've run about 25 galloons and had no problems untill now, but I think it was the wire. I ordered the Denso 02's just to be safe.
