fuel pump question
Old Jul 21, 2005 | 09:05 PM
blue-ss-camaro's Avatar
Default fuel pump question
I am being giving a walbro 255 in take univeral pump how hard is it to wire one of those up to a 2000 camaro?? also how are 42lb lucas injectors???
Old Jul 22, 2005 | 11:37 AM
CrawlinWS6's Avatar
Import Patrol
there are easy, all you need to do is cut off the existing connector which plugs into the oem fuel pump and put the supplied electrical fittings. and get somke 5/16 fuel line hose and attach that to the new pump, all you need is 2 hose clamps (i used oem style hose clamps) stay away from the cork screw style because they eat away at the hose, and get 2inch hose clamp any style will do to clamp the new pump to the harness, and about 6 inches of 5/16 fuel line hose.
